GS-911 frustration!
Motormed
North Wales
I'm after some help with a GS-911 USB (yellow), that I've just purchased, please.
I'm experiencing issues getting my laptop (a 64-bit system running Windows 10) to recognise it.
As detailed in the instructions, I've downloaded the driver software then plugged the GS-911 into a USB port.
On doing this, I get an error message (pic 1) followed by further messages (pic 2).
I've tried the following to rectify it:
Unplugged the device, uninstalled then re-installed the software and plugged into different ports.
In Device Manager, after looking at Properties for the unit (pic 3) I uninstalled the device.
Finally, following advice from the Support and FAQs section of the HEX Code website under the title Previous work-around,
I changed the domain name and disabled the driver signature verification.
Still doesn't work :blast.
Anyone out there with any ideas :confused:?
Could it be that you have been supplied with an unserviceable unit ?
Or your using a charge only usb cable and not a Data & Charge cable
Duff USB port (s) as well
Is the unit unserviceable? It's certainly a possibility, stever1.
As for the cable, it is the one supplied by HEX - the thick data and charge one.
Thanks for your replies so far fellas, any more ideas out there?
Plug it into a bikermates pc (one with a functional gs911)
North Wales a little far from me but laptop available if you’re passing through Yorkshire
Cheers guys, I'll try a different USB cable tonight and also roll back the computer to before I attempted it in the first place.
Failing that, I've asked a tech guy in work to have a look at it tomorrow :duno.
Have you tried other USB ports on your PC? My Nav 5 is quite sensitive to which one I use on my laptop. It will only work on one of the three installed. Yet they all work with my old TomTom.
Right guys, got a positive result after getting home from the pub after a few beers :beer::beer:
I think it was probably down to trying a different USB cable though!
After going through the same routine as before but with GS-911 now linked via a Garmin Zumo cable........it works!!
Instantly went to a registration page so I could change user details and so on.
So a big thanks for all your suggestions and a :beerjug: to bolsun especially!
Cheers,
Med.
Cheers,
Med.
Good result. Buy worrying that the cable supplied was the culprit.
Hi Onahi
We haven't manufactured yellow devices in over 7 years, so I suspect the unit was most likely 2nd hand, which means the cable might've been damaged over time.
Thanks.
It's good to know you're on here !
I've just got my new GS911. And love it.
