GSAde
If I were to fit the Ohlins, front & rear from my standard GS to a GSA by what amount would it reduce the seat height? (My shocks are on the softest setting if this will make a difference)
I'm 5'9" & when I tested the GSA with low seat option that was fine in the height stakes but due to the reduced padding it was less comfortable than my standard GS seat. Would reducing the height by fitting the Ohlins as stated above enable me to use the standard GSA seat? I generally run with my current bike on the low (840mm) position but can get away with the high (860mm) setting - I note the GSA seat height is stated @ 900mm - what would the Ohlins drop this to?
Any info / advice gratefully received.
Ade
Ade
