I have just heard this, has anyone else?
Er what’s wrong with the current brakes?
My new bike is in build mid to late October so we will see
I doubt there’s much objective difference - a caliper is a caliper and pressure is pressure.
Different pads might make it feel different, maybe.
Got my '21 in July and it came with Brembos.
I know what badge I want on my brakes, ive seen a bowl in showroom under leaking front calipers (Hayes) cost cutting gone wrong, imo of course
No,
But the first five years of my professional career was designing & testing brakes with Girling. (Where are they now…?)
So why would one brake fade and the other not?
Were the two “experiences” effectively the same?
Was the fade due to pad material overheating (resulting in poor braking)or fluid boiling (resulting in no brakes at all)?
Were the pads equally worn, equal thickness, equal weight?
Same fluid, same age, same water content?
Same heat into the brakes from earlier driving?
Same bike, same weight?
Does one caliper retain (significantly) more heat than the other?
Were the discs the same, diameter, thickness, material, weight?
I don’t know if the Hayes and Brembo pads are interchangeable, they may have different pad & swept areas, neither do I know if the discs or master cylinder are different on the two installations. Different master cylinder and caliper piston areas could give different feel, but would not affect fade.
I don’t recall ever suffering fade on my bike brakes, though I have in cars, both in testing, and in “real life”. Maybe I don’t push the bikes hard enough.
