I've been using the same BMW Tank bag for the last few years on a '06 GS; '06 GSA and '09 GSA. I've just picked up a '10 GSA today and been told that the little 'velcro' strip, that I used to buy each time I swapped bikes, was no longer available. It used to be around a fiver and is the bottom item in the picture below.
The item that IS now available comes as two smaller strips of 3M velcro.
My problem is that the 'velcro' on the original strip was a very firm - almost like a childs stickle-brick (not sure why I had to indicate it was a childs....but there you go). The 'new' strips are crappy velcro.
So.......I've removed the 'used' sticky bit that was on the bottom strip in the picture and my question is whether anyone knows where I can get some replacement 'sticky' tape that will be as effective as previously supplied ?
Cheers.
Cheers.
, i bought an older bag for my 2010 at a good price, BUMW will supply the new fitting for £15 for the 2010 so it can still work out cheaper
