Gs water cooled alloy wheel
sparkieboy29
cardiff
Hi there guys I’ve bought a set of alloy wheels as a second set for winter use as the spoked ones are a nightmare to clean through the winter, the rear is missing the valve that sits in the rear wheel on its side( much better idea by the way much easier to top up air !)
Any idea what it’s called if available separate from the wheel ?
Depends if you want the pressure sensor or not. £100
Or just a tyre valve
0.80p tops
this part
