GS1300 brake and throttle assembly angle adjustment?
  • Thread starter Thread starter DS
DS
UK & Provincia de Malaga.
Apologies if this has been asked before, but can I assume you have to remove the bolt in the SOS housing to get to further bolts in order to rotate the whole assembly? Can not find it in the manual or on YouTube Tube anywhere🧐
Advice much appreciated. Gracias.
You are right. Remove the small bolt and then move the SOS housing out of the way. The normal two torx bolts are then revealed.
