GS911 question - adaptations / resets
Santa-2512
Omnipotent one
North Pole
Just hooked up the 911, to look at smoothing the throttle on the GS
Its a bit on / off below3K , i'd like it a bit smoother.
went to look how to reset the TPS -
Can find it anywhere in the 911 menu's
any ideas where it resides?
Mart
You can check the tps operation from 0-100% using real time values.
Just reset/relearn under adaptations.
Don't think that alone will solve your problem though.
Sent from my GT-I9505 using Tapatalk
Which year GS is it - with my 2010 TC I had to change the fueling as they tend to run lean which makes them snappy
