Bendy toy
The rear caliper seals cost about £20 from BMW or Motorworks. If the pistons are not behaving, strip the caliper and fit new seals. You'll then be able so see if it needs new pistons as well.
If one or the other piston will go in smoothly but they both refuse to go all the way, then you probably have too much fluid in the reservoir. Suck some out with a syringe.
DO NOT USE BMW organic pads. The linked braking system will chew them to the metal in under 4000 miles.
Front brakes cost £60 per caliper for seals and pistons. Strip and clean before they start to bind and you might save the costs of new seals. That's remove pistons and all seals, clean, grease with red rubber grease and replace).
Once again Bendy your definitive, untroubled by doubt proclaimation needs to be qualified. That may be your experience with one set of pads where you either have a heavy foot or there may be a problem with your particular bike. My experience differs markedly: my bike 2011 twincam, 27,000 miles and the rear pads are only 30% worn.
