GSA pannier frames bushing help
Davy Doherty
Derry
Can any of you fellas tell me measurements of this bushing there missing on the frames I got recently it's the number 14 bushing which is under the passenger seat.thanks
Without taking my bike apart I can't give the measurements. But if you use the shorter spacers where the long ones should be the panniers sag slightly and wont be 100% square to the bike centreline. Its easy enough to swap the spacers and refit the frames.
You can get them form BMW for not much money. Most dealers will post small parts.
The frames are a very fussy design.. TT really should do better.
Yes I read on here about them sagging if the wrong bushing is fitted. I'll give hursts a shout for my missing ones.thanks bendy..
Mine sag slightly but I haven't bothered to swap the bushings about. Use plenty of anti seize grease in the bushings. Mine had rotted at the ends where they contact stainless frames or washers.
