Sold Guzzi V85 accessories…Givi Top box plate & oEM fog lamps
AustinW
Garstang Lancashire
More stuff from my V85.
Givi Top box plate specific for a V85TT. I bought just the plate from someone on here without the necessary fittings as I had some Givi bits n bobs in the garage. The rubber bumpers are not quite right but fit fine with an extra washer and I made the necessary spacers to fit the bike’s rear carrier. Again my handiwork is far from perfect but it all clamps down just fine and a top box is nice and secure.
£35posted.
I’ve also got an old somewhat battered Givi top box (Maxia 45litre??) you can have with the plate. It looks fine but has seen some life. Several keys and waterproof but the catch to release the carry handle needs sorting. Otherwise fine. I think there’s a pillion backrest too somewhere. If you want it it is Free with the plate if you collect, or +£5 for postage with the plate. That would be a decent top box system for just £35.
Moto Guzzi OEM for lamp kit and brackets.
Fitted more or less from new they were working just fine minutes before I removed them. Easy fit to the headlamp subframe - bolts included - and fitted with two superseal connectors that should mate to their opposite in the loom under the dash (that’s where mine were). It’s a tight fit in there.
There’s a bit of corrosion that’s lifted the paint on the main bodies which I’ve patched in such that when fitted you only notice if you know. These are eye-wateringly expensive new. I’m asking just £150.
IMG_9483.jpegIMG_9509.jpegIMG_9510.jpegIMG_9511.jpegIMG_9512.jpegIMG_9513.jpegIMG_9514.jpegIMG_9515.jpegIMG_9516.jpeg
All sold.
Actually I’ve got the top box but I think I’ll take it to the recycle centre.
