Eddy802
Overbalanced to the right (this time!) at a filling station on sunday. bike went down, all happens in slow-mo doesn't it? I ended up rolling around, and when I'd finished my gymnastics, snatched the bike back up onto it's side stand.
First inspection shows:
No damage to me.
Bike has scratches on hand guard and mirror, minor scratches on the head cover and plastic insert....
and gravel rash to H&B bars. far worse than last time I lay her down and further around to almost on top! I look down and note that the bars actually wedged directly in teh expansion gap between the concrete slabs. Perfect fit and burried half depth. On closer inspection I note that the forward side bolt is lose and when I handle it, it comes away along with the spacer for that side and someof the engine block metal!
It seems that the first 3 turns of engine block thread have been ripped out and are still on the end of the bolt.
When I later wash her down the rear indicator lens drops off. Some super glue repair has sorted that one.
Options to repair or restore the engine bar situation?
It seems the bolt only actually goes in about 4 thread turns at most (is this sufficient?) so a longer bolt , and there is room for a further 10mm at least, is one option. I daren't ditch the bars.
As a second thought I wonder if anyone has had their bars re powder coated, min could do with a looking at....
No damage to me.
