Hall Sensor question...
Possu
Oxford, England
Hoping someone can clarify this:
The sensor fitted to my 2001 1150 has a different (Bosch) part number on it to the others I've seen. It also has 5, not 4 wires going in to the conector block. Motorworks have confirmed that at some point there was a change but no model year is stated - does this mean that they're interchangeable?
After thinking my sensor had failed recently, I bought a used example from Motorworks but want to confirm its compatability with my bike before deciding on whether to return it or not.
Strange. I can only find the same part number for all 1150s, for all years, including GSA's. 1100 has a different part number from the 1150 tho.
P'raps it's been replaced with a wrong 'un before?
So wasn't it the hall sensor after all?
Apparently not, just returned from a quick 1,200+ mile trip to Madrid & the Picos, no problems at all (unless of course I don't count getting punted off the bike after being spun round 180 degrees on a Spanish roundabout.....:blast).
On Saturday 6th, had bike ticking over for 20 seconds, it cut out, I left it & then the fuel pump started pumping for 10 seconds whch should not happen without the engine turning (I think?). I fitted Ela's fuel pump relay & off it went, ran fine. I imagine a relay is little more than a switch?
The Hall Sensor from Motorworks did not arrive in time for the trip. I fitted a new relay Tuesday night, did a 30 mile test ride & went to Spain following AM. Only other thing I did was to clean the Hall Sensor - it looked dirty from fording & geberal offroading.
You want to watch that geberal offroading - the little furry fellas aren't keen on it at all. :D
Anyway - where were you today? There's me dropping into NOG to get an MoT and I spot a rather nice Harley Sportster 1200 on the forecourt (doncha love those traders?). Mr Possu nowhere to be seen... :D
Although there was a change in the 1150 hall sensor, they all fit and work the same.
You can't interchange 1100 and 1150 sensors. The plug is different. :rolleyes:
But i'm sure if you spliced an 1150 plug onto an 1100 sensor ( or vice versa) it would work. Although you'd also have to work out which wires go where, as they also changed the wiring colours and order.
