Possu
What are the symptoms of a dodgy Hall Sensor?
My 48,000+ mile 2001 1150GS has an intermittent fault whereby it occassionally fails to turn over when the starter button is pressed. I can hear the fuel pump priming when the kill switch is in the RUN position. When the bike does not start, there's no noise from the bike at all i.e. no clicking starter relays or solenoids similar to when the battery is flat. When the bike does fire up, it always does so immediately, normally never requiring any use of the fast idle lever unless it's exceptionally cold. If I bump start it, it runs perfectly.
I've replaced the right hand switchgear, starter relay & starter motor with exactly the same intermittent symptoms. Sometimes the bike is fine for a week and then it just lets me down. I can see no pattern to problem i.e. only when it's hot, cold or raining? Sometimes it starts within a minute or so, other times, it's hours.
It's fitted with a Datatool alarm, I've just emailed them asking for their opinion and asking how easy it is to disconnect the alarm. I know enough not to just rip it off the bike. Wondering if the immobiliser function is not being disarmed when I press the alarm fob - is this possible or likely?
Could the Hall Sensor be the culprit? Is it wired in to the ignition only or is it wired in to the starting system also? The fact that it's intermittent makes it a PITA to trace.
All sensible help & ideas appreciated.
Thanks in advance.
Steve
Thanks in advance.
Steve
