Hammerite smooth silver Paint on barrels
Den
Scotland
Has anyone used this stuff on cylinder barrels or heads.
I cant find any temperature ratings for it.
When I was a marine engineer I would often spray rebuilt engines with Hammerite and never had problems with heat, even on air cooled engines.
I don't think you will have any problems.
Tim
Used it on my airhead heads and rocker covers with no problems at all.
No, that doesn't make it an air hammer head. Or a hammer head air. Or anything else.
i've seen this stuff used on 1150 rocker covers with no heat problems.
i use it on all sorts of things. MUCH nicer finish than hammerite, rather like powder coat.
I used smooth silver hammerite on the head cover on my 1200 GS after a low speed spill and also to refurbish a second hand one after another higher speed spill on the other side, I really ought to be more careful... Good finish and matches quite well with no subsequent problems
I used it to touch up the inner parts of the barrels. The only problem I had was it smelt for a couple of days but it hasn't flaked off or anything. Trouble is its dirty again and you can't tell it's been done :rolleyes:
