Hand guard indicators
Mad Paddy
adare co limerick ireland
My 1300gs came with enduro pack fitted which I ordered the indicator are stalk type
Have now fitted hand guard indicators to bike but can’t get cable connectors to match up to original on indicator cables
If I splice one indicator wire and join the other to it will it show a fault up on dash ?
How’s the progress going with this. I have a similar issue and already have a question about it lodged with BMW.
Not fussed if the stalk indicator stays and even works but I want the hand guard fitted and the indicator's in place and working.
There is a BMW indicator cable that plugs into the connector under side to panel .
Hi do you want to sell the blank inserts that came in your hand guards now you have removed them for indicators ?
Yes but there’s only one plug on each side of bike under both side panels for the indicators
And I don’t want to splice wires
The other option is a Cansmart with harness for T3 lights just change the plug to a BMW ONE
I may have found a solution basically a Y lead that powers both stalk and hand guard indicators. The chap making me the loom has done one before and no Canbus issues.
I have retrofitted the hand guards running indicators. I used Ezcan and programmed them as running lights as well as turn signals.
Hi 5jms5
I'd be really interested in some info on this please as I am about the order a 1300gs with Enduro Package Pro and really want handguard indicators as well...are you able to share any links or info please?
Huge thanks in advance :)
Hi there buddy, did you wire the hand guard indicators into one of the ports/line on the ezcanto do this i assume?
Thanks fella
