handel bar help
scubamouse
Bedford,England
have looked on here for help in removing the heated grips there is bolted on part to the handel bars that has the grips and brake and clutch on, am after painting the the bars and replace the grips with new ones.
thanks for your help
Mick
Pull the rubber back on the inner end of the grip and you'll find a small xheaded screw
In addition,note that the wiring from the grips runs through the handlebars then goes to a connector block just behind the headstock....just below and behind the front lip of the petrol tank.
Thanks for your help found one screw but missed the one the other side.
all sorted now.
Mick
