Handlebar pull backs
trancey
North East
Anyone fitted a set of pull backs to an LC GSA? I damaged my shoulder last year and need the bars to be closer to my body and was looking for recommendations on a closer position. I've been riding a Ducati Multistrada and the position has been really good, so looking for a similar position as my GSA is due next week.
Called bar risers otherwise. Yes, makes it a helluva comfortable on long rides.
If you need higher bars - get the standard Wunderlich ones from uncle norman - 25mm up only.
If you need higher and closer to you - get the 40 mm up and back. I have these and they work wonders.
Check out the Rox Risers - lots of adjustability. Here are some on my F800GS.
:thumby:onthe 40mm 20 up 20 back ,also rox risers even more adjustable to suit your needs.
It eliminated the ache i had across the top of my shoulder blades on long runs .
Yes as well to the 40mm up and back rox risers, as for cables etc , on the GS it is best to (easy) but I don't know about the GSA.
Hi all,
Who in the UK stocks the Rox Risers?
Looks like they will do the trick.
Cheers,
Bob
I got these from Nippy's, Part No: WUN-41970-111. Admittedly they are on a GS not GSA but they lift and move the bars towards the rider. I was getting pain in my upper back and shoulders but these stopped it. As for fitting, they are simple and on the GS there was just enough slack once the first ty-wrap was cut on the brake cable. Says they are for GSA as well so should be ok?
