Handlebars...
carlhowe
Northwich
Some twat knocked my bike over while it was parked. Damage is scuffed engine bars (not a problem), broken left switch cluster and damaged handlebars.....the threaded bit the bar end weight/handguard fixes to is bent downwards by about 20 degrees. Any suggestions?
That's quite a weak point, if the rest of the bars are straight you could just bend that bit back.
If you get really stuck I have a spare set.
Are the threaded bits removable? If so I will have a go at getting the bent one out.
