Just back from our holiday and the GSA once again did its duty well. I did notice that the rear suspension is not up to the task. Same as last time. It is all ok when with the missus alone but loaded with luggage (weighed the luggage and add about 13 kilos to each pax for clothing and we are just under max all up) the bouncy thing doesn't do so well. I guess it is time to visit the suspension guru. Local dealer referred me to Rally Raid but 2.5k front and rear or 1.5K for a rear shock. You gotta be kidding. The rear shock for some reason decided to trough a wobbly by deflating (reduce preload) on starting the bike but then adjusted again. Curious.
I guess I will be looking at a rework and progressive spring at most, hopefully just a progressive spring will fix it. Any recommendations?
It needs more power but Hilltop is booked for next weekend so will judge the result by that reliable pants dyno. If my arse can measure to the nearest micron anything I pass then I reckon it is good enough as a dynometer. More fucking power BMW!!!!
