Hardwiring a Drift Ghost S camera on aR1200GS LC (K50)
Better picture
Sent using Tapatalk
The link says "Sorry, this content isn't available at the moment, The link you followed may have expired, or the Page may only be visible to an audience that you aren't in." :nenau
Like the way you have the camera mounted R R :thumb2
I have taken a 12v supply from the plug under the seat, just to the rear of the tank, not campus, and fed a 12v accessory unit comprising of two usb outlets and two cigar outlets and run lead to camera which as a result is always live with ignition switched on. No problems running camera and charging lead for the accessories/phone whilst on the go.
I just use a pedco bracket on my upper crash bar and power from the din socket when running a camera on the bike.
Got my Mounts and it is all attached now. Just waiting for my wiring to come from China. Using GS GoPro mount with a ¼" threaded adaptor.
Do you have a list of components for your mount and a photo of how you fix it to the bike? TIA
Looks tidy! I use the 1/4" thread too but on a RAM.
I'd change to your version if it's tidier though!
What Go Pro mount did you use?
TIA
Yes please give us a breakdown of the parts you used - looks excellent !!
Have same camera and mounted similarly running off the front power socket.
Want to mount a second drift to the rear: how best (and easiest way) to permanently hardwire to battery but to only record when engine running
The power bank will also suppress any spikes from the bikes electrical system & maintains power even whilst starter is engaged..
Enjoy..
IMHO, this may be the better option. I believe, from experience, that a power spike does mess with the internals. I had a Ghost HD 'die' on me after a ride out with the camera attached to the power outlet on my 2014 GSA. Had to buy a new one and will not be making the same mistake again.
FWIW, i had run this camera on the helmet in all weather with the mic attached and no issue with water getting in.
On a separate point though, a friend of mine has designed and 3D printed a replacement back for the Drift Stealth so that access can be made for the power cable.... works a treat. :bow
