harman kardon speakers suddenly buzzing /humming
Deleted account 211028001
just started never played loud
if usb removed still a low volume noise from the sticks and woofer gets louder when usb plugged in
if disconnect the sticks still audible from woofer but much quieter
purchased 2nd hand off here a few months ago granted but the sudden appearance of this is baffling
ideas anyone? or are they for the bin :nenau
attached to iMac 2012
Check that all the other plugs in the back of the machine are in properly.....and pull and clean all plugs associated with the speakers.....if there's a small short between two poles of a speaker plug (just a bit of fluffing up can do it) then it will do the buzzing thing
if noise present with usb removed, it's unlikely to be contact problems, check for proximity of any of the speaker wires (including its power lead) to other power cables.
Sounds like a mains induced humm...
mains induced hum by the sounds ( no pun!!) of it.
starting running via an extension lead? recent equipment plugged into the same circuit?
try them powered from elsewhere
