Have you ever?
Engineer
Outing the ideological nut jobs of this site
Bedfordshire
....ridden your WC very slowly on a level surface at tickover revs slipping the clutch over its full range? If so have you noticed the way the engine develops more power as the clutch lever is released to its full engaged position and how the engine power is reduced when the clutch if fully disengaged?
How would you know how much power the engine develops in either clutch position ?
you can here the revs rise very slightly and the bike pulls a little harder as you fully release the clutch (throttle closed) the revs rise as you let out the clutch lever and fall as you pull it in, counter intuitive?
Just the electronics looking after you. The K1600's do it too. Reduces the chance of stalling it.
How are you measuring the "power"? - or don't you know?
(do you see what I did - there? :rolleyes:)
Al
Yes apparently so - I didn't realise this until yesterday - in order to do this then the engine management system must be able to detect the clutch lever position by using multiple switches or a potentiometer - interesting:)
Two switches on the clutch I 'fink
That all makes sense now - clever stuff, but kinda assumes that people can't use the throttle properly and need a bit of help :) but I guess that with all this computer assistance then BMW can optimise the fuelling even at very low engine speeds and compensate by tweaking the throttle just enough to keep everything running.
So - humour me...........
How does the engine "develop more power" exactly? All you've done is pull in and let out the clutch?
Al
Hmmmmm, not difficult with electronic control over the throttle and fuel injection is it? if you know the clutch position and feed that information to the engine management systen then one can easily control the throttle independent of the user (open the throttle a bit, more power) - that's what a fly by wire throttle can do, the engine management system can take over control from the rider.
might not have even to change the throttle position, change ignition timing slightly maybe, adjust fuel injection level maybe, tweak the butterfly open or closed a bit or all three????.
So - where is this extra power being dissipated? Again - all you have done is clutch in/clutch out.
You seem to be getting bogged down in electronicness..............
Al
Al
OK try this, if you feed a signal into the engine management signal telling it to open the throttle a bit then it will do that, agreed?
if that signal comes from a switch on the clutch then you have clutch control over the engine output power, agreed?
If you have two switches on the clutch, one that switches just as the clutch is first pulled in a little bit and another that switches when the lever is all the way to the bar you have two signals to feed to the engine control system, agreed?
so when the clutch lever is all the way back to the bar one could close the butterfly a little (and/or tweak the fuel, timing etc) and the power/revs are reduced.
When the clutch lever is almost fully released then the other switch operates and you feed that signal to the control system and open the butterfly a tad and get slight more revels/power.
do you see now? maybe my explanation is not good enough but ask Shunt he knows how it works.
