IMeantToDoThat
OK, OK, maybe the answer is somewhere hidden in the forums but I've tried looking and can't find it.
2006 F650GS Dakar
What I'm trying to find is the connector that the hazard light switch connector plugs into. I know it had one...
Basically about a year ago I had a fairly big off and destroyed the little panel that the ABS switch and the hazard light switch mount in. I've just gotten around to refitting a glued together panel and discovered I can't remember where the switch plugs into.
Hopefully a stupid question with an easy answer - but having just used up all of next years bad temper budget removing the relay mounting only to discover the connector wasn't uder there after all I any assistance would be good.
And I apologise again, I'm going to post this query elsewhere so you might see it more than once, sorry!
2006 F650GS Dakar
