Heading to the Plymouth gerry
MAR.600
GLASGOW
Travelling down to macclesfield the warning light came on the dash.
Light just above the abs it isn't flashing
Solid light .
Bike is running fine no other warning
signs .
Tried turning off to reset just the same
Called BMW didn't seem to no what the problem was told me to pop in to reset or check for any codes.
If I disconnect the battery would it reset??
Any I do would be great thanks
Martin
Sent from my SM-G950F using Tapatalk
Ferry lol
In view of your circumstances I would disconnect the Batt for a few minutes.
a picture would help - any words on the LCD as the yellow light can have many meanings and is an indicator to read the main display?
No indicator lamps on .
Green unleaded fuel.
vDS ( vertical down sensor ) Bring the motor cycle to the upright position, switch the ingnition off then on or the kill switch, from the riders manual :)
Sorry late in getting back to u guys.
Left the light decided not to mess
about with it.
Half way round Spain the light went off for no reason .
Not booked it in to bmw garage.
Also noticed the front panel below the headlight surround loose ? Any had this issue.
