Headlamp connector
Bendy toy
Torbay, England
Does anyone know where to buy a connector to fit the headlamp three pin plug? I want to make a patch lead for alternative bulbs with trigger wires for relays to do other stuff.
I want a female to plug into the one labelled "lighting power connector" A blank male to plug into the headlight would be handy to keep it clean. Where can I buy one? Does anyone know what it's called?
Here it is pulled out of its rubber cover.
Hi Bendy, I did all this last year, converted headlamp to LED and fitted auxiliary spots on relays. I think the connector you need (to match the one moulded into the back of head lamp housing so it plugs into bikes loom) is an AMP 3 way/pin male junior timer plug, Tyco/Bosch type.
Sent from my SM-G935F using Tapatalk
Excellent thanks. I can now put my wiring loom back to standard. It's annoying me as it is (though it is working just fine). :)
