Headlight bulb cover part numbers 2011 1200GS
mpgscott
Isle of Scalpay, Western Isles
Hi,
Selling the bike and i had HID's fitted which involves cutting holes in the headlight bulb covers to allow the fitting of the HID bulbs, so my intention is to simply swap over the ones on the GS for the new GSA's when i get it. However if they are cheap enough i might get a set, have had a look on ebay and googled it but cant find them.
These are the things: https://www.google.com/search?q=r12...ic.jqibmepixmfsgvdi%26pageId%3D166140;440;340 so any ideas on part numbers??
Ta
Halfords do some large grommets that fit in the hole. Put them in mine when i took the hid out. Then whoever has bike next had the option of popping them out and putting hids in again.
Can you remember what size th gromit was you used, i took out of mine basically the outlined circle on the rear of the cover, currently away from home and cant access to measure but hoping i can order some off ebay for when i return.
