bsogri Registered user Joined Feb 24, 2004 Messages 480 Reaction score 0 Location sunderland Oct 18, 2007 #1 my gs 1200 ,dash board showing fault on front headlight but lights are ok , any clues please
ktmmark Registered user Joined Apr 6, 2005 Messages 1,050 Reaction score 0 Location matlock derbyshire Oct 18, 2007 #2 Check both high & dip beam are working also if you have a spare try changing it as it monitors resistance
Les Wassall HiD50.com leading light in HiD UKGSer Subscriber Joined Jan 15, 2003 Messages 4,038 Reaction score 9 Location Cheshire Oct 18, 2007 #3 Side light bulb
ECM Registered user Joined Feb 4, 2005 Messages 510 Reaction score 0 Location Netherlands, Zoetermeer Oct 18, 2007 #4 Y'r kidd'n.. That little light? My high beam is not working for weeks now. LAMPF showing all the time. Is this due to that litte idiot light??
Fanum Toubab UKGSer Subscriber Joined Apr 26, 2003 Messages 48,939 Reaction score 8 Location Secure unit 2 Oct 18, 2007 #5 Clean all terminals and connections as well...I've seem faults caused by corroded/dirty spade terminals even with the bulb working fine. I presume it detects the increased resistance and 'thinks' it's a fault
Les Wassall HiD50.com leading light in HiD UKGSer Subscriber Joined Jan 15, 2003 Messages 4,038 Reaction score 9 Location Cheshire Oct 19, 2007 #6 ECM said: Y'r kidd'n.. That little light? My high beam is not working for weeks now. LAMPF showing all the time. Is this due to that litte idiot light?? Click to expand... Possible, make sure all the bulbs work including the little one, if the fault is still there unplug them and re connect make sure the pins are clean
Magwych Well-known member UKGSer Subscriber Joined Feb 20, 2006 Messages 1,370 Reaction score 47 Location La Salvetat Peyrales, Aveyron, FRANCE Oct 19, 2007 #7 ECM said: Y'r kidd'n.. That little light? My high beam is not working for weeks now. LAMPF showing all the time. Is this due to that litte idiot light?? Click to expand... Or, the LAMPF is telling you your high beam is bust
Big Lee Registered user Joined Jun 21, 2004 Messages 2,831 Reaction score 5 Location Cumberland Oct 19, 2007 #8 Is the little arrow pointing up or down. If it`s pointing down it`s the backlight bulb fault. The backlight will still light up but will have either the tail or brake light bit blown.
