hi guys, just a quick question, has anyone or everyone have the high beam section of the headlight steam up all the time. it clears eventually if hace full beam on for a while but comes back again. have i a leak into light unit or just the cold conditions........
many thanks.......
many thanks.......
If you drop by your local camera shop you can get a small bag of silica crystals(Usually on a piece of string)leave in the headlight over night (seal it in as best you can) and it should absorb any moisture in there.If the steaming up reoccurs then you will need to seal the rim.
