bignosebry
Hi
I've managed to disconnect the headlight throw adjuster inside the headlight unit - don't ask! So when I move the switch up and down, the reflector doesn't move and the headlight it permanently throwing too high and dazzling!
I've got the unit off and there appears to be a white plastic socket that needs to clip back onto a metal ball, right at the bottom. But I can't reach it. I presume the glass is sealed and cannot be taken off the unit?
If anybody knows how to solve this, your wisdom would be much appreciated.
My last option is to cut an access hole in the bottom of the unit and seal up afterwards.
...so stupid made system
I tried removing the glass to repair from the front but eventually decided drilling a hole in the back made more sense - managed to get the white ball joint back together ... but then it easily popped off again.
