Heated Grip stopped working
JJ Jeremy
Member
Petersfield, England
My RH Heated grip has stopped working at 40k. Bike is Nov 08 GS1200. LH one is fine. Bahnstormer are saying it needs replacing which sounds about right. Any ideas of where I can buy a used one and how easy it would be for me to fit it. Just a case of undoing the nut on the end of the bar and sliding off?? Thanks for any help . JJ
heated grip replacement
Mine (2004 1200 @ 48k) went recently and couldn't find one second hand, so bought new at £70. Fitting reasonably straightforward, but you need a set of torx bits (going down to very small sizes). The whole of the switchgear has to come off and it's a bit fiddly. I did it without consulting a manual, and I'm pretty sure there wouldn't have been a lot of any use about it in there anyway.
Follow your nose and you'll manage (I did). If I was as helpful as a lot of the nice people on this site I'd have taken a series of photographs and put a step by step guide up, but I'm a bit rubbish like that and I was in a rush.
I'm hoping the left one doesn't go as well, as the £70 is a bit painful!
Neil
If you fancy repairing it to save around £60, try this page
