In my experience all tyres wear squareish, probably because regardless how twisty the road most of it is straight. But, the K60 starts square and only gets worse. However you don't really notice it for ages - 3000 miles in my case, and you soon adapt your riding style. I rode the Tail of the Dragon in the smokey mountains and several other ultra-twisty roads in the USA in the wet and the dry with no problem down to boot skimming angles of lean. However as they wore I kept getting the odd moment when the tyres moved a bit and then I lost confidence. The squarer they got the more they would pick up any striations in the road or wear in the road. The front was noisy too - although it was kinda nice to play tunes as the noise made varied with speed and angles of lean. The "knobblies" also make the ride rough.Did the back tyre go square because of straight roads in USA or do these tyres all go square after a few thousand miles?
I used Conti Road Attacks on a previous bike. They were stunningly good for 3000 miles (about 60% worn) but they squared off and became some of the worst handling tyres I've used.
I've not had such a squaring off problem on the GSA but it handles so well I get to use more of the shoulders. It's also not had any Conti RAs.
I don't want tyres that force me to point and squirt like a newly born again rider who can't do bends.
They are not tyres for hooning around on but, like I said if I was setting off on a 6,000+ mile tour I would fit them again. They are tough tyres that wear well and an acceptable level of grip.
BTW its not true that all roads in the states are straight. Far from it in the mountainous areas.
