Help 1987 K75c instrument panel block connectors
Stevey B
South of the Watford Gap
Hi
I have a 1987 K75C, my winter project, which I'm converting into a scrambler using unit garage parts. Part of this conversion is changing the standard clocks to a digital one. Has anyone done this and if so the wires in both block connectors, what do they relate too.
I have looked at the wiring diagram and I am the first one to admit its baffling.
Stevey B
from what I can recall, it's a complex box of tricks in the 'breadbox'
Simply removing it means the battery no longer charges and other issues.
lots of stuff on K forums about some kind of connector adaptor box that I can't remember the name of now, a simple plug n play, but expensive option.
The guy at BSK speedworks may be able to help you
www.bskspeedworks.co.uk
