Help find my leak
Steptoe
Him/Bloke/Fella.
S/W London.
My tyres gone flat - i need to know where the hole is.
Can anyone tell me, i've looked and i can't find it . :eek:
Can`t find yer own hole!! Bloimey, you been at the Domestos again? :D
First, check the valve. 90% chance that it's there.
Second, get some very soapy water, and apply it liberally to your wheel. Put some air in the tyre. Spin the wheel looking slowly for bubbles.
Most tyres normally go flat at the bottom, so check there first ;)
:hapybnce: :hapybnce:
Steppers,methinks the irony of your thread has been missed....... :D :D ;)
While I`m here......I`ve just noticed that none of my bikes have oil leaks....
What can be wrong with them.............??? :mmmm :mmmm
Tarka, are you sure they have oil in them to start with?
If they haven't get the guy with the oil leak to send you some of his!
Sorted.
Why would you put oil in your tyres?
Maybe I should put some ultraseal in the engine to stop the oil leaks.
Very funny :tosser I dont see why theres a need for that kind of attitude. Maybe it because i'm not in clique? I didn't see you trolling thatthread maybe its because i'm not a sponsor eh :dabone
Any advice would have been useful, especially from somone who obviously knows more about spannering GS's than most on the board.
Posted into my thread at 10:59 and created this one at 11:01. Nicely done.
that thread was a bit more precise in the location, and type of leak .
:D :D - i must go for a leak, before i wet myself ;)
it's because they don't have knobbly tyres on :dabone
hink I found them......................
Neil, check that is not the rim. I had the problem before and the cause was a spot of rust on the edge of the rim. Emery paper solved the problem (after removing the tyre, of course)
