- Joined
- Oct 10, 2004
- Messages
- 3,583
- Reaction score
- 63
I'm having some problems with a new battery on my F650GS twin. Three different symptoms:
1. Often (but not always) when I start the bike, the battery has difficulty cranking the
engine. But when I test the voltage it is normally reasonable (12.6v or higher).
2. I've had the battery on an Acumen optimiser half a dozen times in the three weeks since
I fitted it and most times (but not always) it fails to turn the light green and when I test the
voltage--even after 22 hours on charge-- it's less than 13.2v.
3. The battery seems to lose its charge fairly quickly even though I've been running in lower
gears with everything but the headlight switched off.
Although it's short, the video below shows several things
a) voltage one hour after a longish run is around 11.8v (not good)
b) dials go through the self-test sweep as I switch the ignition on
c) voltage drops to 6.1v as engine cranks
d) voltage rises to 13.3v on tickover
e) dials go through self-test sweep again (due to the low voltage during cranking)
It's not a great example as the engine was warm so it caught very quickly, but sometimes it cranks very slowly for two or three seconds with the voltage below 7v. I think I may know what is wrong but am no technical expert so I would welcome views from fellow GSers.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/Jb7b5XZBfqU"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Jb7b5XZBfqU" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
i'm driving him nuts with questions.
