alfie Active member UKGSer Subscriber Joined Jun 14, 2007 Messages 255 Reaction score 2 Location Eastbourne, East Sussex Aug 31, 2013 #1 A bit of advice 1150 gs removed front wheel a while ago not sure if I'm missing a spacer. As your sitting on bike right hand side is there a spacer that goes on the spindle between forks and wheel. Thanks
DrFarkoff Grumpy Ole Git!!! UKGSer Subscriber Joined Jun 27, 2006 Messages 14,239 Reaction score 2,307 Location Islandmagee, Co Antrim NI Aug 31, 2013 #2 there is a small wheel bearing cover about a cm ish wide and the speedo drive is on the left side When you fit the wheel spindle the step bit is much longer by design so that it pushes against the wheel bearing cover to space the distance
Pekkavee Registered user Joined Oct 10, 2007 Messages 576 Reaction score 8 Location Finland Aug 31, 2013 #3 DrFarkoff said: there is a small wheel bearing cover about a cm ish wide and the speedo drive is on the left side Click to expand... Number 3 in this picture, I quess. Pekka
alfie Active member UKGSer Subscriber Joined Jun 14, 2007 Messages 255 Reaction score 2 Location Eastbourne, East Sussex Aug 31, 2013 #4 All sorted thanks
