HELP to find wiring connectors
mikecbrxx
Peterborough, UK
I am trying to track down a supplier for some very specific, and small, wiring connectors. See photo.
These connectors are the ones that fit inside the block connector that sits at the back of the X instrument cluster, so the heart of the bike. I am trying to source them through BMW but am just getting blank looks at the moment as it appears to be a part that can not be found on their computer systems.
Can anyone help ?
BTW, Conrad Electrical have something similar but not the same. As you can see, they are very small and hollow. I guess its about 1mm across the hole and the diameter of the connector would be about 1.5mm (ish). They have to lock into the wiring block hence needing to get exactly the some one.
It looks like I will also need a specific crimping tool.:nenau
Found them.....
If anyone else wants/has to get into this level of wiring, the connectors are available here.... at Dataspares. The plug is the one in the link , though you need to call them to just get the pins for it. Min order is 20 at (currently) 34p each.
There are other locations but they only want to sell you a whole plug with the connectors at lots of £££££'s. Here.
For information, this same ECU plug (26 way) is used on some Suzuki's and Ducati's but on BMW's it was only ever used on the X bikes!
