HELP.WHERE CAN I GO WITH NOT ENOUGH TIME
  • Thread starter Thread starter stumac
stumac
hi all,looking for some advise,ive got at max a week to spare in july and fancy going somewhere myself a wee bit different to my usual run which is scotland,i was thinking france through the pyrenees into barcelona and back,what do you think with the time ive got?
A week, starting from Belfast? I guess that means a day to get to the Continent and a day back? That leaves you five days.
I am not sure where you arrive in France, starting from Belfast. Either way, I would consider lowering your sights a bit, or you are (near enough) going to get to Barcelona in time to come back. Of course it's rideable in a day, too, but it's a holiday you are on.
I assume you will arrive on the west side of France? Once you get south of roughly Le Mans, France really opens up and there are of good roads, places to stay and fun to be had.
Have a look at the map sticky to see the maps you need to have a look at. There are also lots of threads on routes, where to go and what to see. Work some idea out and come back with you outline plans. Lots of bods here will then help you fine tune your plans into a really good holiday.
the ferry takes me from southern ireland to rosscoff.18 hrs each way,so probably 4-5 full days riding.i dont mind staying in barcelona for just a night and heading back,my thoughts were to ride most of the day at a very relaxed pace with plenty of short stops for pics etc
what you reackon?
What do I reackon?
I reackon it's a long way.
I reackon Roscoff to Barcelona, direct is 800 miles.
I reackon Roscoff to Barcelona, avoiding all toll roads, motorways and giving a reasonable preference to minor roads, is just over a thousand miles.
I reackon, if you want to take two days down and two days back, you are going to be averaging between 400 and 500 miles a day.
I reackon, if you are planning to have a relaxed pace ride down the highways and by-ways, stopping off for plenty of pictures along with coffee and sticky buns on a regular basis, you had better start early in the morning.
i reackon you have put me off,do you recommend another trip?
or do you think i could just leave spain out and head to the pyrenees?
OK
Let's start.
You have four to five days days away in France, before having to be back at Roscoff ferry terminal for your 18 hour return sailing.
What time does the ferry arrive in France?
What time does the ferry depart from France?
Do you want to camp or stay in hotels? Do you want to stay in reasonably large towns or in the deep countryside?
How many miles a day do you normally do on your holidays in Scotland?
What time do you want to set off in the morning?
What time do you want to finish in the evening?
You say you want to meander and take pictures, I guess you want to avoid too many motorways, which is fine.
Do you want to stop for:
Elevenses
Lunch, say an hour
Mid afternoon tea
Do you want to see a sight or two?
They are all possible, so don't worry, but they (along with photo stops - and ciggy breaks (if you smoke) - all reduce your moving time significantly and it's a big country.
Are the Pyrenees a 'must' do?
Have you got Gramin or some similar route / distance / time plotter?
Have you got any maps?
you could visit New England....:augie
The haute pyrenees are still a big ask in a relatively short time. You could try the Massif Central, loads of truly stunning roads and scenery and a bit more accessible. L:)ook at Le Puy de dome in the Vulcano region, Millau viaduct and the nearby Gorge du Tarn. Its the area around Clermont-Ferrand if you look at a map of France.
all i want is abit of an adventure,i dont know anyone into touring on bikes other than you guys so im cluless as to what to do and where to go,but i can tell you 250-300 miles a day max,mainly camping,riding from 9am-5pm and i want to see the mountians because i enjoyed scotland so much. spain is not that important,i just thought down the west of france and in to the east of spain via the pyreenes would be a good run.
or is there better closer?
OK, that's no problem at all....
It's a good run OK to the Pyrenees but tricky if you want to do 250-300 miles a day, leisurely, camping, 09.00 - 17:00 with stops in between. You may run out of time... simple as that.
Let's see what we can do.
Go first to the map sticky http://www.ukgser.com/forums/showthread.php?t=136891
Michelin are not the only maps but they are right at the top of the pile for tasks like this. Definitely buy the Michelin 726 tourist map and the 1;200,000 scale map book. You do not need any other maps. Use a GPS by all means, they are fantastic, but a map will help you plan things out much better. Plus they always work and a local can help you.
On country type roads (I am not talking about farm tracks, or tiny lanes) you will probably not average over 40 mph. Probably much less if you stop for pictures, relaxing and a long lunch. So, if you rode for 10 hours, non-stop, you will go 400 miles maximum. On the topic of lunch. France by-and-large stops for lunch 12:00 - 13:30. Arrive at one and they may say sorry. Monday can also be a tricky day, certainly in the morning, as many shops in the rural parts and many towns will be shut. It's part of the country's charm and you can't change it.
You want to try to avoid making your route too intricate, with too many left, right, left, turns in the middle of nowhere (France is big and very rural). It's fine if you are in a car but a real pain if you are not used to it, are not really sure where you are going and it's loshing with rain.
Do not avoid motorways or the major roads out of bloody-mindedness - or because it's not 'cool' - if you really need to get somewhere. An hour on the motorway could be 80 miles. The same hour on some D roads? Probably 30 miles, so that's two and a half hours out of your day, possibly wasted.
From a very quick look at the 726 map, I would consider:
Roscoff, roughly south east to Poitiers. There are perhaps two ways of doing it:
(1) Roscoff, Lorient, Vanes, Nantes, Cholet, Poitiers (jolly scenic and you could stop off to see the U-boat pens and the huge standing stones) but it's slow and you could end up spending three days just doing it.
or
(2) Roscoff, Rennes, Angers, Poitiers (direct)
Or, by adding a bit, south east to Saumur (a very nice campsite by the river) then east a bit, Chinon, Loches, Chatillon-s-Indre.
Either way, get yourself onto the 726 map's green Bis roads running down to Limoges. The green Bis roads are easy to follow 'tourist' routes. They may sometimes be true main roads but they are still fine and above all easy to follow. Use them with confidence.
From Limoges you have a choice:
Limoges, Perigaux, Agen or Montauban.
Limoges, Emoutiers, Tulle, Aurillac, Rodez, Albi, Castres, Carcassonne. This will take you through France's central mountain range. They are not the Alps (for sure) or even Pyrenees but not bad, just different.
Limoges, Perigaux, Agen, Auch, Tarbes, Pyrenees.
Return the parallel route, from the way down. It's easy to plan with the 726 map.
Run out of time and not making it? Don't worry. Stop and change plans.
How?
Look at the 1:200,000 scale map and find the yellow (preferably green bordered) roads around where you are or nearby. These 'green' roads are different. These are scenic roads and could be going anywhere.
What else:
You could lob in a detour to the Millau bridge, that is on a motorway, so easy to get to. But it's a day (by the time you have looked the bridge, taken pictures, had a wander into the museum) from the Pyrenees, don't forget. Or you can just ride over it, or look at it from the bottom.
You could stop off at Oradour-sur-Glane to see where the Nazi army murdered hundreds. Or you could be a bit different and pay a visit to the forgotten village at Maille, where something truly dreadful happened, too: http://news.bbc.co.uk/1/hi/programmes/from_our_own_correspondent/7512078.stm One might take a day or an hour, it's up to you.
In short, a broad square: Angouleme, Clermont-Ferand, Millau, Auch (a huge area) is stuffed with great roads, campsites and 'stuff' (as my daughter would call it). You could spend a week just going, Bererac, Sarlat, Figeac and all the places in between.
Planning and a bit of research is half the fun. Getting lost is the other.
I hope that gives you some ideas.
PS
Don't forget to buy decent travel insurance. It is very cheap (see umpteen threads) and criminally stupid not to have it.
Don't forget recovery for your motorcycle. It's dumb not to have it.
If in doubt, work out how long it will take you to push your bent bike back to Ireland with broken legs and a temperature of 102.
Don't forget your passport, green counter-party driving licence, your V5, your EU medical card, your original insurance certificate and your MOT cert (if required). Copy them in case you lose them.
If in doubt, the fine for not having some of the documents can eat a tidy hole into your meal plans.
Don't forget your waterproofs and sun glasses / tinted visor (you are riding straight south, right into the sun).
this is the kind of info im looking
many thanks
Jolly good. :beerjug:
The best tip is to keep things simple. Realisation that France is huge country and that all the 'Must do' things on the way are often not possible, if you want to get where you are going and have a holiday, is a great place to start. The truth is none of them will go away in our lifetimes, so you can always go and see them another day.
Read through some of the Travel threads or many excellent trip reports, come back if you have some questions.
what about heading to the alps,would it maybe be a better choice i think its about the same distance
Six of one, half a dozen of the other.
The Alps are huge, vertically and horizontally, crossing from France in the west to Slovenia in the east, via, Germany, Austria and Italy.
You can get to the French Alps in a day (motorway) or two (motorway and scenic) but you may well be better off heading for Calais than Roscoff. Head towards: Annecy, Chambery, Grenoble, Gap, Briancon. Then in roughly east and north east.
You will see the route easy enough on the 726 map.
If you go before mid-June the high passes WILL be shut.
Hi Wapping, sorry to but in, its just I am trying to plan a route as well and you sound like you know what your doing, any advice on the following.
Tunnel Friday night, etap Calais overnight and then want to do the following before getting on a boat at Bilbao Friday night.
French National Motor Museum
Milau Bridge
Stelvio Pass (or similar)
Maranello
Monte Carlo
Andorra
Pamplona
Bilbao
Taking tents, but would prefer etap/formula one, thinking of motorway 1st day to get South and the mostly avoid toll roads, planning to go Firday 5th June.
What do you reckon.
Thanks in advance
Danny
Fly to Munich or Spain and hire a bike. You'll be in the twisties a few hours after leaving home. Fly-Ride is the best way when you only have a week to spare.
Regards,
Kieran.
the alps it maybe then,motorway there and scenic route back might be my best bet.
