help wiring Twalcom lights please
holla916
Runcorn England
Hi all. My latest bit of bolt on bling from Twalcom arrived yesterday and I started to fit them this morning. brackets and lamps fitted but the fitting instructions are in Italian and the pictures are so dark you can't make anything out. Anybody fitted this kit? Where did you mount your relay and where did you tap the live feed into. The bike is a 2010 TC. Any help would be very much appreciated
Many thanks
Never fitted this kit but your feed should come directly from the battery. Mount the relay close to the battery if you can. Thats the way i did my FF50s
Done it! mounted the relay near the headstock, the earth onto a nearby frame bolt and the other 2 wires back under the tank - one to the positive battery and the live feed from the aux plug under the tool tray. They are not wired in to the headlamp feed and so I can turn them on and off with the handlebar switch. Every bit of this kit is superb from the handlebar switch bracket to the brackets for the spots with stainless fittings and spacers. very pleased with the result, another quality piece of kit from Twalcom, From Italy to your front door in 5 days!!! great service
The switch mounting looks very neat, where from please ?
....................................................... really? :) :) do the stickers not give it away? ................... Twalcom. Its in my first post as well :) yes the switch is very neat, infact every part I've had from Twalcom is quality together with great service. Get some bits bought .............................. and say that Ian from Shrewsbury sent you :)
