Hepco & Becker Gobi's - help required
NeverRodeBefore
Manchester
Having purchased a set of Gobi's off this very site, which I knew came without frames, I sent for a set from motobins.
I started to build the frame rails and panniers together and then noticed that the pannier mounting blocks are supplied with the panniers. As I don't have the actual mounting blocks, what are my chances of being able to get them?
Whilst I'm at it, don't suppose anyone has the instructions from a set of Gobi panniers? I'm assuming that I'm only missing the two blocks that bolt to the rails?
All you'll need are the mounting blocks which are available from Motobins as a separate part.
If your really stuck and can't wait for them to re-open I have a new set in my spares pile which I can let you have but let me know asap as I'm off on the Calums Road trip on Monday. :bounce1
Erm, I won't know if I'm really stuck until Monday? However, there is no great rush on my part. If I'm truly stuck we can sort it out when you get back?
