Hepco Engine Bar Refurbish
Rusty Bolts
Like putting old pair of slippers on
Plymouth, Devon
Just completed refurbishing some engine bars that I got from Tuby Kay of this parish. They were that badly corroded that he had to cut the cross tube in half to get them off.
As they arrived in the box minus one spacer. Thanks to Timpo for making me a new one and then posting it on-top bloke!
As you can see looking pretty 'orrible
Tools assembled ready to get them apart
Luckily, Tuby cut them at an angle which made aligning them for welding a lot easier
All welded and ready to take to the powder coaters
TBC
So they came back from the powder coaters a little bit too silvery but I'm sure they will dull
It's amazing what you can hide under powder coating
As always exercising good tool control.
As you can see it doesn't blend in too well with the other framework
All done although I did struggle with positioning the tax disc until I remembered there was a whole thread on it
Total cost to refurb including buying them was £40 which isn't bad plus I got to fettle in my man cave for an evening
Rust ol bars
Shity start turned around nicely,job well done and more satisfying than just throwing new bars on ,they look semi chromed :D:thumb
Cheers 1157:beerjug:
They do resemble semi chrome. I think it is due to the depth of lacquer on them. As an experiment I scuffed the mating face engine mounting plate with scotchbrite and that dulled it down leaving it not dissimilar to the rest of the bike frame. Ill see how it wears and perhaps scuff the rest of it.
Good bars, had them on my 04 and they saved it in a long slide about 30mph in the wet (diesel on a roundabout).
