chipsonfriday
Recently fitted a pair of HIDs to my GS. As usual the difference is fantastic. However I have a problem...
Dipped is fine but when I put the main beam on I lose the instruments, speedo, tacho and the instrument back lights. Switch the main beam off, then second or two later the instruments recover and continue as if nothing has happened.
I played around abit today on a short ride out and discovered that if I put the main beam on (instruments fail) then turn them off again after about ten seconds the instruments recover and I can use the main beam without any further failures - until I leave the main beam off for a few minutes.
I have mounted the ballasts on top of the headlight housing and the cables from the main beam run very close to the instrument housing.
Has anyone else had a similar problem?
Chips
Chips
