HID's & LED's
'Nuffsaid
Surrey / Wiltshire / Lahndan
I thought I would show of the full range of lights now that I have them all wired up. Quite pleased with the overall effect ..... A bit OTT? :eek
Sequence goes:
Led's (ICE LIGHT) and Side light
Plus Dipped HID
Plus BWM Fogs ( Standard bulbs .... not for long )
Plus Wunderlich Micro-flooters
Plus Main beam HID
Now the next person that says " Sorry mate , I didn't see you ....."
:mcgun :mcgun :mcgun :mcgun
Looks great :thumb2
Please excuse my ignorance....but what is H.I.D ?
I want to improve my headlight. Is there a simple way of doing it i.e. replace the bulb? Is that what H.I.D is?
Gary
You took so long to fit them that the grass needs cutting again:D
Looks great :thumb2
Gary
Gary,
HID = High Intensity Discharge ..... it means the bulbs are rplaced with gas filled "burners" that are ignited by arcing a high voltage current accross them. They are usually known as Xenons. They used to be really expensive, however you can now source kits off Ebay for as low as £40 a light to convert. If you are interested, search the site under HID and you will find loads of usefull twaddle all about the must have accessory. .....:thumb2
Were did you mount the ballast?
The only problem now is the ambulance chaser that tries to claim for the Sun Tan :cool:
:D
Gary,
Thanks for the info, could be the answer to my problem !
:D
Les
Ballast (x2) for Low & High beam are mounted at the front of the tank one to the right of the "well" and one opposite the light unit. I will mount the ballasts for the Fogs either under the beak, or under the seat or rear rack - I haven't decided yet. When I have them fitted, I will post some photos.
Only one ballast mounted (at the moment ;) ) fitted it here.
