High beam not working
  • Thread starter Thread starter RoteEddie
RoteEddie
After riding my bike home to Norway from Germany I discover the light switch is not working as it should. When switching to high beam, the lense is only flashing on as the switch is operated. Probably a bad connection in the switch.
How do I fix it and how costly will it be? I have asked the dealer to send me a replacement part, but no answer yet.
And yes, I deserve a kicking for not checking the bike properly before taking it home :mcgun
Try spraying a load of WD-40 into the switch and turn it off and on a few times. If the light only flashes when you hit the switch, it's probably a problem with the switch contacts. If there was a wiring issue, the light would probably flash on and off intermittantly as you ride (as long as the switch is in the "On" position).
Its a known problem. I had the left switch cluster replaced as a fix.
I met a guy on a 1200 at this years TT with exactly the same problem.
I disconnected his battery, touched the pos and neg together which discharges the capacitors, do a throttle re set by opening and closing the throttle a couple of times, reconnect the battery.
Started the bike and about 20 seconds later the main beam was working again:clap
Sounds like voodoo :) I'll give it a try unless wd40 does the trick.
PLEASE NOTE This SHOULD NOT be the pos and neg battery terminals connected together!!!!!!!:eek: :eek: :eek: :eek:
and if you put your tongue across the battery terminals this will show you if theres a charge in it :D
please don't, if your tongue is that long consider the porn industry:thumb
Which reminds me..:aidan
What does a 9v battery and a womans arse have in common?
You know it's wrong but sooner or later you're going to put your tongue in both of them:P :eek: :D
