I suspect I've read too many threads on adding lights that work with high beam. I can't figure out where to route the wire to get at the high beam. There's apparently a 'grommet' on the headlight housing where you can feed a wire in, but I can't see it for the life of me. Or does one just drill a hole in the headlight casing? I'm assuming 'those that know' just tack on a bit of wire to the back of the bulb connector ???
Perhaps a pic would save a thousand words.
Although an innate ability to use search would probably alleviate some members blood pressures
