High Intensity discharge lamps into Airheads ???????
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
Can anyone give me a reason why we don't hear much of fittin High Intensity discharge lamps
into Airheads especially RT and RS?
I have a friend who wants to pinch my kit for the GR and fit it to his airhead
I seem to recall reading somewhere that the HID inverters are susceptible to
the voltage changes of an airhead??
Any comments or thoughts?
Edit useful comments chaps and chapesses! Puh~Leeez?
i wonder who that could be :augie:augie:augie:augie:augie
could you not put in a smoothing capacitor on the input
I thought about it but the headlamp on mine is pretty good anyway so no urgency. I don't know if there's enough room to fit the longer bulb in the clamshell anyway. I think I've got some HID bits lying about somewhere so I might have a go sometime.
Airhead HID
I fitted a Hi Lo beam HID to my R100GSPD a couple of years ago. The spec says that the invertors work down to about 8V, draw less current that a conventional Halogen set up and are considerably brighter. The downside I have found is that the beam pattern is not well defined. ( due to the source of light being a 'blob' instead of a filament for which the lens was designed )
Put it this way, I have not changed back to the original.
Nick
So No one has any downside to fitting an HID and ballast kit into an airhead
I had worries about Voltage but they seem to work down to 8 volts
My only other thoughts are Vibration and the igniter and cooling the bugger inside an RT fairing???
Any further offerers of advice ???? BEFORE I go fit the fecker?
