SJPB1982
Does anyone use the more explosive jungle juice and if so do you notice any diffrerence?
Octane rating at the "pump" is ferk all to do with calorific value, it's its resistance to knocking or pre- ignition... Stick with recommended.
Da doo RON RON
True but you'd expect the higher octane fuel to allow the engine to run more ignition advance more of the time, without the knock sensors intervention; thereby leading to more efficient use any given volume of petrol.
I suspect this is particularly true for '08 onwards bikes which run a higher compression ratio.....![]()
yes, slightly smoother and a little more responsive.
more mpg too which i suppose is inevitable... given its a higher octane rating.
It might seem odd that fuels with higher octane ratings burn less easily, yet are popularly thought of as more powerful. Using a fuel with a higher octane lets an engine be run at a higher compression ratio without having problems with knock. Compression is directly related to power, so engines that require higher octane usually deliver more power. Some high-performance engines are designed to operate with a compression ratio associated with high octane numbers, and thus demand high-octane gasoline. It should be noted that the power output of an engine also depends on the energy content of its fuel, which bears no simple relationship to the octane rating. Some people believe that adding a higher octane fuel to their engine will increase its performance or lessen its fuel consumption; this is false - engines perform best when using fuel with the octane rating they were designed for.
Using Super Fuels
One of our users commented that using higher octane fuel than your engine requires actually gives no benefit and may be a waste of money. This is because virtually NO engines require 98 RON over 95, and the market for 'super' fuels seems to be based on people's misunderstanding of octane ratings and the placebo effect of filling up with 'more powerful' fuel - making motorists think their engine is running better in some way.
What do the fuel companies say then, to justify the "increased power" claims for the super grade fuels? Some companies say that while all fuels contain cleaning additives, 'super' fuels contain more or better detergents to keep the injectors cleaner than standard fuel. Others say the fuel is a few percent denser which gives slightly more power per litre. These benefits may be marginal though in comparison to the extra cost involved so it is worth ensuring that your engine will actually benefit before filling up.
There are all sorts of engines that would not care if it was high octane or not.
