Historic Environment Record of Northern Ireland (HERoNI)
Mzokk
Belfast NI
(Not to sure if this should be in GPS info, the Ireland section or Travel UK&Ireland Richard)
The Department of Communities publishes maps of the industrial heritage of Northern Ireland here.
the maps include information about.
  • Archaeological sites and monuments
  • Historic buildings including listed buildings
  • Historic designed landscapes
  • Industrial heritage
  • Defence heritage
  • Maritime and marine heritage
  • Agricultural and sporting heritage
  • Battlefield sites to name but a few
When you access the map viewer you can click on the relevant subject matter and display the information on the map.
This is defense heritage that is information relating to WW1, WW2, the Cold war and the Troubles. Most of it is WW2 and mainly centred around airbases. The table widget in the picture allows you to view the raw data the map is based on and you can filter the data. Below is a subset that shows cold war Royal Observer Core (ROC) sites. They are described in the table and their condition is indicated.
[td]
A network of 1,518 underground monitoring posts were built across the UK to house the volunteer staff from the Royal Observer Corps (ROC), who, in the event of a nuclear attack, were tasked with recording the blast yield, location and drift of radioactive clouds caused by the detonation of Soviet nuclear weapons. There were 59 of the small underground posts evenly distributed across Northern Ireland. A crew of three could operate for three weeks. Their results would have been transmitted to a regional ROC group headquarters, which for N. Ireland was the 31 Group HQ (DHR 310) in Thiepval Barracks, Lisburn.​
[/td]​
[td]
Site appears largely intact with both access shaft, BPI and ventilation shaft in situ, however both the shaft and access shaft have lost the ventilation louvres. Access hatch retains its original steel hatch cover.​
[/td]​
The tables or filtered subsets of the tables can be exported as CSV, Json or GeoJson files that can be imported into Software including Basecamp and Google Mymaps.
For Garmin devices data from the site can be downloaded onto the unit as Custom POI's via POI loader.
And it retains the information for the site that you have selected from the CSV that you imported. This example works for defence heritage but would equally well work for sites and monuments i.e. Cashel's Souterrains and Megaliths of which we have many.
The site also has historical mapping. Could this Ford (beside my aunt Lizzy's old mill be the longest in the UK and Ireland at 1 Mile??
