fatjohn
Sorry to bother you all with a non-GS question, but I'd appreciate any advice you could give:
Basically, when I got to work this morning I found a nail rammed in at an angle on my 1,500 mile rear Tourance.
Booo!
It went in to the side of one of the tread blocks, out the side and angled down slightly to enter again at the base of another block. Now, the tyre is a radial tubeless type, but the bike's a Transalp so I'm running with inner tubes and it seems to be holding pressure ok, so I assume the inner tube is undamaged. So the question is: do I need to be concerned? Does it need repaired/replaced, or is a case of keep an eye on it, but if there's no evidence of a slow puncture then the tyre is still sound? In other words, can the structure (and therefore safety) of a radial be compomised by a nail through it, if the wheel is running an inner tube?
Sorry to ask you all to put your long distance virtual diagnosis hats on, but if anyone knows anything about this and has some advice, I'd be really gratefull!
Booo!
