hughguzzi
Hi all - after a bit of advice or ideas !! my son's xl 250 degree (grey import xl 250 with dohc, 4v, water cooled, electronic ign,) its got a non standard can. got some camchain rattle, he fitted a hid 'unit' in the headlight.
Problem is occasionally, seemingly for no good reason it dies. sometimes when not warmed up, other when been riding for a while - rain or wet not an issue.
Engine struggles as if for lack of fuel and sometimes it picks up again, sometimes just stops. Will start again and run fine. Most times he goes out it does this once or twice but runs perfect otherwise. Every time I take it out for a spin its fine even when going steady, ragging it, or fiddling with electrics !!! Ive stripped the carb and cleaned it out - wasnt bad at all, checked electrical connections and sprayed wd, spark plug ok, choke ok. i'm a bit baffled ! need to sort it before he comes to grief on it because the engine dies unexpectedly.
some ideas to try out ??
