horn upgrade question
bisbee
VIGILUM
Newark Notts
I need a better horn (on my 1150gs I fitted the stebel magnum) my new1200gs has esa so not a lot of room to fit anything bigger in oem location so what have you put on and where please?
On my first 1200RT it had a twin horn akin to that found in Beemer cars then cost cutting the next RT model was down to the silly beep that is also std on the GS. On that RT I upgraded to a BMW 3 series car horn - same fittings and bloody loud.
I havent tried the same on the GS but worth a try.
Bisbee, have a search on this section 'fitting horn' or 'sebel'. Although the space is limited you can fit a Sebel. I fitted a Magnum. Have a look through the threads and there are some photos suggesting how to locate it.
